Relè assistenza avviamento
Aperto da FaGuS..., 07 Maggio 2019, 11:19:29
FaGuS...
Salve a Tutti,
ll costo del relè in oggetto (12R819500100 - https://www.bike-parts-yam.it/yamaha-motocicli/parti_di_ricambio_di_assegnazione/12R8195001) è di  circa 80€ (un furto!!!).
Per caso questi che ho trovato su aliexpress sono compatibili ?
https://it.aliexpress.com/item/32883443398.html?productId=32883443398&productSubject=Starter-Relay-Solenoid-Replacement-for-Yamaha-29U-81950-92-00-29U-81950-93-00&spm=a2g0y.search0104.3.29.6f325e8aaXPQf4&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_319_317_10696_10084_453_10083_454_10618_10304_10307_10820_10821_537_10302_536_10843_10059_10884_10887_321_322_10103,searchweb201603_52,ppcSwitch_0&algo_expid=962a3e1c-3e47-40d4-b819-3df86fec84df-4&algo_pvid=962a3e1c-3e47-40d4-b819-3df86fec84df&transAbTest=ae803_3
https://it.aliexpress.com/item/32885970351.html?productId=32885970351&productSubject=4Pins-Starter-Motor-Relay-Solenoid-for-Yamaha-YFZ450-YFZ-450-YFZ-450-2004-13&spm=a2g0y.search0104.3.107.6f325e8aaXPQf4&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_319_317_10696_10084_453_10083_454_10618_10304_10307_10820_10821_537_10302_536_10843_10059_10884_10887_321_322_10103,searchweb201603_52,ppcSwitch_0&algo_expid=962a3e1c-3e47-40d4-b819-3df86fec84df-15&algo_pvid=962a3e1c-3e47-40d4-b819-3df86fec84df&transAbTest=ae803_3
https://it.aliexpress.com/item/32969074412.html?productId=32969074412&productSubject=Starter-Relay-Solenoid-for-YAMAHA-WARRIOR-350-YFM350X-1987-2001-Motorcycle-Starter-Solenoid-Relay-Motor-Accessories&spm=a2g0y.search0104.3.114.6f325e8aaXPQf4&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_319_317_10696_10084_453_10083_454_10618_10304_10307_10820_10821_537_10302_536_10843_10059_10884_10887_321_322_10103,searchweb201603_52,ppcSwitch_0&algo_expid=962a3e1c-3e47-40d4-b819-3df86fec84df-16&algo_pvid=962a3e1c-3e47-40d4-b819-3df86fec84df&transAbTest=ae803_3
Sull'Africa misi un relé aftermarket per SH125, sono 8 anni che sta lì. Pagato 22 euro. Prova a fare una ricerca sugli scooter yamaha.
FaGuS...
#2
Questi sono per scooter, quad e piccole moto yamaha
Io proverei , al massimo butti 4 euro ma se va bene ne risparmi 76!!! ;)
FaGuS...
Alla fine ho preso il relè del terzo link.
Appena mi arriva (credo tra un paio di mesi) lo monto.
Per il momento continuo ad avere il ponticello fatto anni fa!
FaGuS...
Relè arrivato ma non ancora provato, voglio fare delle prove con il tester prima e poi vi faccio sapere.
Rosario Schimio
io l'ho dovuto cambiare due mesi fa perché il vecchio rimaneva incollato
Comprato in negozio a 35€ la marca non la ricordo, ma non era un marchio conosciuto... Per ora tutto bene
FaGuS...
aggiornamento
ho alimentato il relè con la 12 v e misurato la resistenza sugli altri 2 pin: funziona benissimo e la posizione dei pin è la stessa del relè originale yamaha.
Una volta finito il test del relè ho deciso di provarlo sulla moto e fa una cosa strana: con la moto in folle il motorino di avviamento non gira, nemmeno premendo la frizione; mentre, se inserisco la marcia e premo la frizione il motorino di avviamento gira...
Premetto che il sensore del folle non è originale ma di concorrenza.
Avete qualche idea sul perché?
FaGuS...
Avete qualche consiglio su cosa può essere?
Citazione di: FaGuS... il 05 Luglio 2019, 12:54:48
...fa una cosa strana: con la moto in folle il motorino di avviamento non gira, nemmeno premendo la frizione; mentre, se inserisco la marcia e premo la frizione il motorino di avviamento gira...
FaGuS...
Che cosa strana... l'interruttore del folle accende correttamente la spia N sul quadro, ma fa sta cosa strana
Billy
Hai provato a vedere cosa succede se rimetti sotto il vecchio relè originale?
Se sparisce l'anomalia (mi pare strano) allora è qualcosa del nuovo relè, se invece il problema resta vuol dire che magari inavvertitamente hai sminchiato qualcosa. Prova.
Mille misure un solo taglio
Hai provato ad invertire e/o spostare i fili sul rele,? ::)
Citazione di: FaGuS... il 11 Settembre 2019, 14:15:42
con un voltmetro prova a vedere se quando pigi il bottoncino arriva la tensione d'impulso per far scattare il relè
FaGuS...
#14
Citazione di: Billy il 11 Settembre 2019, 15:20:01
non lo avevo il relay, avevo fatto un ponte...
Citazione di: Marchinovis il 11 Settembre 2019, 21:08:28
non ho provato...ma le posizioni sono giuste, ho verificato con il tester
Citazione di: gianfranco1104 il 11 Settembre 2019, 21:26:45
ho provato, ma non ricordo cosa fa...riproverò, ma in ogni caso non so se il relay deve essere sempre aperto o sempre chiuso!
